King pins baby! You don't see those on a 44 every day. The truss is .188 wall. I have a number of pictures that try to show the difficulty of fitting a long upper link with the axle at full stuff, but it is really hard to get a good clear look at things in real life let alone in pictures.
Overall from below:
Drivers side from below. The upper link is sitting in there, but you cannot see it because it is above the driveshaft. If I put the upper here, there would be too much separation at the frame end compared to the axle end. It would be around 7" of separation at the frame end. The axle end is around 7.5" right now.
Axle end of the upper with it sitting on top of the driveshaft.
From the front.
near the frame end through a hole in the tranny tunnel.
There's no room for the upper between the tranny and the driveshaft though.
Maybe I can fit the frame end of the upper in here to the left of the driveshaft?
Here the temporary link is slid in to the left of the driveshaft as far as I could go without more hole cutting.
From inside through the hole:
The axle end with the link forward, but going back to the left of the driveshaft.
I think I'm going to cut the hole bigger and figure out some sort of mount to place the upper to the left of the driveshaft with about 5.5" of separation with the lower. BTW, I asked the same question over on Pirate, so here's a link to that discussion:
http://www.pirate4x4.com/forum/showthread.php?t=799859 There are some interesting pictures in that thread. Jeff
