I've done a little more thinking and came up with what I think is going to be a slick setup for the passengers side knuckle. I've been concerned about the stock Ford King Pin steering knuckle strength and had figured that at some point I would plate them. Well, a company has now came out with a kit of pre-cut pieces to weld on. It is kind of expensive, but I'm tired of cutting and grinding my own shit and hope this kit will fit and work well. Here is a link to the Pirate thread about their kit:
http://www2.pirate4x4.com/forum/showthread.php?t=774943 $150 shipped for enough pre cut pieces to plate both knuckles. Then, after they are plated, I am going to weld on a custom 1" spacer on the passengers side. It will be clamped in place by the normal four studs and then welded all the way around the upper part of the knuckle tying it into the plating. This spacer will also have the extra two holes drilled and tapped for two additional studs! Placing the rod end UNDER the raised arm places it in a pretty good spot for clearance and matching the track bar. I hope to also tie the bottom of the rod end to the stock steering knuckle with some plating.
Here's a mock up of the tie rod at full stuff. The track bar is in as well, so you can see how parrallel they are. I cut my nice double shear Astro Van pitman arm apart as well and installed a spacer in it. I'll finalize that once I get all steering links in and tested.
Here's the axle sitting 3" below normal ride height.
Here's the mocked up steering at ride height from the front:
And from the end. Notice how the steering arms are forward of the end of the pitman arm.
Finally, here is a shot of where the coilover is going to have to mount.
I think I'm going to have to mount it taller than I had wanted to clear the track bar bolt and the raised high steer arm, but I think I can make it fit.
Oh, for the drivers side knuckle, I may try to fit one of these from Great Lake Off Road over the plating:
Here's a link to a pirate thread about this product:
http://www.pirate4x4.com/forum/showthread.php?t=748768&highlight=knuckle+gusset&page=6
Jeff
