NAXJA is having its 19th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
does anyone know a link to all the ratios , i have a 3.55 dana 35 on my truck now and i have a 44 with 3.54 . i want to know if any d 35 's came with the 3.54
Your understanding of axle ratios is slightly flawed. Effectively, 3.54 and 3.55 are the same thing.
The ratio is calculated by dividing the number of teeth on the ring gear by the number of teeth on the pion gear, and rounding to two decimal places. Because (for example) a Dana 35 has a smaller ring gear than a Dana 44, the number of teeth to achieve the "same" ratio is different. As long as the ratios are not more than 1 percent different, in operation there is no problem. This is why you'll usually see the 5-speed 4.0Ls referred to as having 3.07 gears, but sometimes 3.08. It depends on which end of the vehicle you're talking about.
