Gauge Install Questions
Steelghost
San Diego, CA
I'm installing a Autometer D-pic gauge and am using a pillar pod as a mount. This gauge needs three wires to splice into. 12v power from Ignition switch, ground, and the headlight dimmer switch lead. I have a 1993. I have three questions.
1.) How do I remove the front left pillar trim. do I have to screw out all the trim in the back to loosen the front trim pieces?
2.) where is the easiest location to intercept the power lead from the ignition switch and what is its color?
3.) where is the easiest location to intercept the headlight dimmer lead from the headlight switch and whats it's color?
I'm going to go at it this weekend and am looking for some words of wisdom before I start. Thanks guys!!
