Prepmech
NAXJA Member #981
- Neoga/Decatur, IL
Getting close to being finished with my axle swap so figured I would post up some pictures.
Full width HP44 front, 9" rear. 35" tires. RE 5.5" extreme duty (drop brackets) lift.
The front is a '75 F150 HP44 that had the welded on radius arm wedges.
TnT HP44 axle swap kit
Pinion angle set at 13 degrees
Knuckles were cut/rotated for 6.5 degees of caster
4.88 gears, Detroit true-trac
Ford knuckles reamed to accept 1-ton chevy TREs over the knuckle
All new brakes, spindles, hardware (stock Ford)
Warn hub fuses
Stock shafts (for now)
Chevy C2500 brake hoses
JKS track bar mount
Shortened RE track bar
RE arms, drop brackets, 5.5" springs
The rear is out of a '79 bronco.
Center is nodular, 4.88 gears, Detroit locker, Daytona pinion support
Blue Torch Fab spring perches
'79 F250 rear brake hose
Early YJ passenger side parking brake cable
DPG bump-stop plates
Still need to weld on my shock mounts
Superior truss
Also in this picture you can see my new OkieFab skid plate/hitch.
Warn hub fuses
JKS track bar mount
Superior truss
