Ok....changed fuel filter,replaced relay to the pump....cranks but no start..
even tried dumping a little gas in the t body.....no worky Grrrrrrrrrrrrrrrrrrr
Ya know how many posts have been made on the subject:
"Cranks but won't start".......
Ya know how many times it turned out to be the CRANK POSITION SENSOR??
Pulled it off yesterday,the only thing that kept on the bellhousing was the 2 bolts and the wire to the pick up....Should have a new one today around 12:00 noon......
Ignore the previous....
New CPS
" Fuel Filter
" Relay (fuel pump)
Still won't freakin fire.....doesn't the ceramic insulator work with the ignition???The one on the left fenderwell.......
New CPS
" Fuel Filter
" Relay (fuel pump)
It was a combination of:
ECM
Coil
Ignition Module
CPS
There was a full moon
It was Friday
The JEEP gods were laughing at me the whole time
All of the above were tested and were shown to be defective.....
I did find out tha there are bout 6 different ECMs that will work in the 89'
all the way from $$ to $$$
