- Maurertown,Va.
On Monday I took my XJ to have the injectors replaced,I figured that a ASE mech who does the work everyday could do the job correctly and quickly.
Tech must have had a bad weekend---I did not watch the job being done--heard the Jeep start in less than 1 hr,then shut off,had a leak at the fuel rail.
Tech then pulled injectors out to try and re-seal them--evidently(sp) not in a straight line as two of the plastic ends on the injectors stuck in the port and broke off,one other was pulled down but not broken off.In trying to remove the broken parts one went into the head,valve was closed on that cylinder,so only thing to do was pull intake,remove plastic part and re-assemble with the old injectors.
Now I have 3 damaged/broken injectors and they want to bill me for 2 hrs labor.
That bill hasn,t been paid.
I have a spare intake ,got home,tried to install the injectors(good ones) in it.Yes a small push & wiggle and they went in fine.
Has anyone had problems with the injectors from Five0 motorsports not fitting in the manifold port?
I need to talk to them and find out if anyone else has had problems.
Thanks for reading my rant---
Wayne
Wayne
