- Gassaway TN
I pulled this out of my 95 YJ. It’s a 30 spline Powertrax Locker with 30 spline Revolution axle shafts. Splines are straight, no twisting or bad spots. Locker worked before I pulled it out. It had 4.88 gears installed on it. I pulled the gears off, you will need a gear set. I upgraded to an 8.8 that’s why it got pulled. The Dana 35 housing is also available if you want it. Axles are drilled 5 on 4.5 and 5 on 5 both.
$500.00
If you have any questions let me know.
$500.00
