FS: Assorted Parts:
Mike L
Anaheim, CA
I have a list of parts that I no longer need. All of these parts are new. These prices do not include shipping that will be on the buyer. No dibs calling, first one with cash in hand gets the parts. Pictures will be available on request. Let me know if you have any questions. Thank you for looking:
ARB
*4 x 160212 : Compressor Tank O-Rings - $3 for all
*1 x 170206 : 5mm Blue Line Union - $8
*1 x 180103 : Solenoid - $40
*2 x 180209 : Switch - $8/each
*2 x 180210 : Switch Cover Front - $5/each
*2 x C-035 : Compressor Pressure Switch - $30/each
*2 x C-042 : Compressor Relay - $10/each
Autometer
*1 x 2629 : 2" Electric Transmission Temperature Gauge - $40
*1 x 2620 : 2" Mechanical Air Pressure Gauge - $45
*1 x 2640 : 2" Electric Transmission Temperature Gauge - $40
Ballistic Fabrication
*12 x BRK-1058-1 : HD 3/16" Flat Bottom Shock Tabs - $2/each
*1 Pair x BRK-1072-1 : Heavy Duty Frame Link Mounts for 2-5/8" Joints - $40 for pair
*10 x BRK-1075-3 : HD 3/8" Flat Bottom Shock Tabs - $5/each
Currie Enterprises
*4 x CE-9114JN : 1-1/4"-12 RH Jam Nut - $1/each
*4 x CE-9114LJN : 1-1/4"-12 LH Jam Nut - $4/each
Dana Spicer
*4 x 43116 : Rubicon 44/D30 30-Spline Inner Axle Seal - $5/each
Daystar
*1 x KJ01010bk : Transmission Mount (98-01) - $40
JKS
*2 x OGS915 : 2" Extended Sway Bar Mount - $10/each
*1 x OGS921 : Steering Stabilizer Mount - $12
*2 Pair x OGS922 : Rear Axle Shock Mount - $40 per pair
*1 x OGS925 : Frame Conversion Bracket - $25
*1 Pair x OGS970 : U-Bolt Plates - $50
*1 x OGS999 : Crossover Shock Mount - $140
Parts Mike
*1 x DMS-FDBB/SB : Set20/Explorer Retainer Plate - $8
Poly Performance
*1 x PPM-3217 : Universal Track Bar Frame Bracket - $30
*1 x PPM-4305 : Universal Track Bar Bushing Kit - $10
Pro Comp
*1 Pair x 97-516B : Leaf Spring Center Bolts 5/16" x 4.5" - $3
Rancho
*1 Pair x RS8128 : Leaf Spring Center Bolts 3/8" x 5" - $6
Rubicon Express
*2 Pair x RE1482 : Leaf Spring Center Bolts 5/16" x 2-1/2" - $4 per pair
*2 Pair x RE1483 : Leaf Spring Center Bolts 3/8" x 4" - $6 per pair
Russell Performance
*1 x 634510 : ARB hose - 5' length Kit (fittings included) - Russell Stainless Steel ARB Kit and Fittings - $45
*2 x 642791 : -3 AN SAE Brake Adapter Fitting - 1/8" NPT Pipe Male 90° SAE Brake Adapter Fitting (Wilwood Brake Caliper to -3AN) - $7/each
Timken
*1 x HM803110 : Dana 60 Inner Pinion Race - $10
*1 x HM803146 : Dana 60 Inner Pinion Bearing - $20
*2 x 6408 : Axle Bearing Chrysler 8.25/Ford 8.8 - $12/each
*2 x 8835S : Axle Seal Chrysler 8.25/Ford 8.8 - $3/each
