bimmerjeeper
- USA
"Rock the wheel" refers to turning the steering wheel back and forth, left to right, right to left, etc. This can be done with the engine off and the steering column unlocked or with the engine running. I prefer to have the engine running, makes it easier. So have someone "rock the wheel" while you are on the ground and looking at the steering linkage and track bar. Look for any visual slop while the steering wheel is being turned back and forth. You can also hold onto the end of the component and feel for any slop as the wheel is being turned back and forth. Hope this helps and Merry Christmas! You can also search for Stu-offroad.com for good tech info.
Al, thank you for the clarification! I will give this a try when a relative comes over. I have already had a mechanic replace the drag link tie rod end ball joint thing, but I guess that could be another item to check for slop while turning the steering wheel.
