Matt S.
- Fresno, CA
Took the *cough*wrangler*cough* out last weekend, and well its obvious that stock flex sucks donkey balls. Oh and to clarify for you special people, that is not good!!
I am only talking front suspension here, so its related to the XJ. Here is what I am thinking to get a tons more flex out of a very small suspension lift. Please help with ideas.
I am getting 2"BB spacers, then going to build a frame mount track bar mount that is similar to the RE XJ bracket so that I can run a hard mount joint rather than a TRE. I think that will give me the most flex. Then get some CHEAP lower control arms and plate them for strength. Get some Bilstien 5150s that only have 4" uptravel and as much down travel as possible. I will have to get brake lines, and I will be making a a HD hiem steering system.
Do yall think that on that SMALL of a lift, I can attain much more noticable articulation? Oh and I dont want to lift big because I am going to be putting 35s on 3" lift (thank god for non-unibody)
Matt
Matt
