joeyschribar
- Edmonton
OK, basically i cant afford (right now) crossover steering on my front d44, and the leaves are in the way of normally mounting the draglink to the tie rod.
what i have planned in my head is to custom build out of heim joints, a draglink and tie rod.
the draglink will be about 1 and 1/2 inch shorter then the original one, so it mounts INSIDE the leafs.
Is there a downside to this, does the drag link need to be as far to the outside of the tie rod as possible?
i tihnk the only other option that i have would be so bend up a Z shaped draglink, which i dont want to do. Whats the importance of having the draglink mounted as far to the outside of the axle as possible?
Thanks!
Thanks!
