No kit, fab the front, use the rear LCA mounts to bolt up YJ leaves. Will need to reinforce the XJ LCA's, MJ's already reinforced.
When you fab, you can use a fabbed crossmember, or if you have an aftermarket bumper, you can add some mounts for the shackles and front springs. I used Confer lift shackles for a YJ. Really help it flex. We used a YJ main leaf eye cut off with about 3"es of the spring attatched. This is welded and bolted to the fabbed bumper.
I used a Waggoneer Front D-44, which has a trac bar. We used the MJ trac bar, shortened and sleeved it to fit. The steering is an altered Waggy set-up.
We also bumped the front axle up about 2"es (my MJ is a 121" WB), so I ended up lengthenning the front D-shaft, and used an internal sleeve press fit, then welded. Stock MJ front d-shaft was used.
Excuse the steering for now. It works, but am about to do the high steer. I have some bump steer right now, and some play inbetween steering left to right. Not too bad, but after driving my friend's with the Drag OTK, ready to get the steering done right. With the 38's, you'll put some major stress on the steering. My frame is boxed on the driver's side, and the steering box is bolted on with grade 8's. I'll add a box brace soon too. I sheered the factory bolts (all three), and put a small crack in the rail on the trip before reinforcing.
I can't take any credit for this set-up, other than being there and lending a hand during the build. My friend came up with this idea, and has it down to a science. He is an experienced wheeler, welder, and a factory Jeep mechanic. Definately get someone to do this that has experience.
The ride with leaves is fantastic. And, I've driven my 'ol now sold XJ with a high dollar Tereflex, Rubicon (with DB's) lift for many years before the MJ. I Love the MJ better than i did the XJ!
