front drive shaft slip yoke
Harlee&Tahoe
having a hard time finding replacement slip side to front drive shaft. 87', 4.0, man.trans. Seems i have a thicker shaft and splines than i can find around. does anybody know anything about this. haven't mic'd yet for exact dimensions but it is thick 16 spline. I have searched through 100's of shafts cant seem to find a match.
Dive shaft?
Pull the whole drive shaft from a 4.0/AW4 and be done with it. There is no reason to try some mix and match thing when you can just replace the drive shaft as a unit.
why aw4? it's going to be a lot longer than his driveshaft.
DERP, hadn't had my coffee yet at that point. I thought he had written auto... :anon:
'87 with a manual and 4.0 doesn't even show up on the chart I have... I'll see what I can find and report back.
OK, this is odd. OP can you verify your specs?
I'm not finding that '87 - 4.0 - Manual combo anywhere.
Might want to just measure the collapsed length of the shaft you have and compare it to this:
XJ 87/88 2.5 Automatic 27.950 53003912
XJ 89/93 2.5 Automatic 27.970 53005540
XJ 89/01 2.5 Manual 25.310 53005541
XJ 89/01 4.0 Automatic 30.660 53005542
XJ 89/01 4.0 Manual 29.250 53005543
XJ 89/00 4.0 Manual 27.080 Export 53005544
XJ 89/00 4.0 Automatic 28.620 Export 53005545
XJ 87/88 4.0 Automatic Export 53005260 *
XJ 95/01 Diesel 27.640 Export 52098208
ZJ 1993 4.0 Automatic 30.530 52098341
ZJ 93/95 5.2 Automatic 32.870 w/o CV 53008427
ZJ 94/95 5.2 A500 30.625 w/o CV 52087805
ZJ 94/95 4.0 A500 w/o CV 52098790
ZJ 93/96 4.0 Manual 52098344
ZJ 93/96 4.0, 5.2 31.875 w/ 231, 242 52087805
ZJ 93/95 4.0 Manual 30.000 w/231 52088090
ZJ 93/96 5.2 33.000 w/ 231 53008427
ZJ 96/98 5.2, 5.9 31.250 w/ 249 & Model 30 52098379
ZJ 1996 5.2 Automatic 32.875 w/ 249 & Model 30 52098501
ZJ 96/98 4.0 33.000 w/ 242 52098707
ZJ 96/97 4.0 Automatic 31.250 52098850
ZJ 1996 5.2 Automatic 30.750 w/ 249 & Model 30 52099246
ZJ 96/98 4.0 33.500 w/ 249 52099260
The actual spline section is much thicker than normal as well as the neck down
87', BA10/5, 231
My 88 MJ has (or had) 4.0, BA/10, 231AMC. I had it around after my AW4/TC swap. I'll look in my pile o' parts and see if it's there...stay tuned.
It's about 4-5" shorter than the 1994 AW4/231J combo.If I find it, it's yours to play with.
Start looking at Ford's, dodge's and chevy front/rear slip shafts ... The current stock jeep stuff is small diameter 16 spline slip ... The truck shafts will be a larger diameter 16 spline slip. It's possible given the age that either it was a swap or just an oddball shaft.
