Front AX-15 driveshaft needed
Jeep450r
Nor*cal
I need a front driveshaft out of a 5 speed Xj with the AX-15 tranny. The slip portion on mine has gotten loose over the years and is completely unbearable now.
Let me know if you have one! I need one by next weekend if possible.
You need a whole shaft or just the slip yoke end. I'm sure I have a few shafts laying around I can pul one off. You can have it for free. If the splines are ok that should be a fix
Probably a whole new shaft... I think the splines are all worn out. Ill try to pull the shaft apart tomorrow after class and check it out.
I could have sworn I posted this in the for sale section. My bad!
Thanks Josh.
I pulled the shaft apart and I cant tell which side is worn... So I guess Im still looking for an ax-15 front shaft.
badabump. still in desperate need of an ax-15 front shaft!
If the slip joint is shot, you're better off replacing the whole thing.
NB: The front driveshaft from the BA-10 in the same vehicle will also work.
kevin go to pnp.
Well I guess I dont need one anymore. I must have tweaked my driveshaft just right on this last rubicon trip becuase it doesnt vibrate anymore! Thanks for the help anyways guys!
