front and rear dana 44
poomero
Tigard
Both axles are Dana 44's from a tj with 4. 10 gears and heavy duty Bones dif covers and 1" wheel spacers all around. Low miles on ball joints and unit bearings. Front comes with 250 wall tubing on the long side Revolution Chromoly Axles with 1350 series U-joints Powerstop drilled and slotted rotors and pads 04 factory Rubicon air locker Rear is set up for a three link with a custom mini truss. drum brakes Open diferential
I also have a ruffstuff dana 44 axle kit so you can put this set up in your xj.
$2000 OBO and i am located in Tigard.
