vetteboy
- morganville, nj
My front suspension setup has been pretty much unchanged for two years at this point...and like XJ's tend to do, once you wheel 'em hard for a while, you need to fix some spots on the unibody that have been a little "overstressed".
The passenger side spring used to be vertical, and the bumpstop used to point towards the ground. Likewise, the driver side isn't doing so well either:
That one is bent the other way, towards the shock. These things happen when you've got limited uptravel, stock bumpstops, and attempt to jump your rig.
Basically both bumpstop towers got bent, and also my "temporary" hockey puck bumpstop extensions pretty much outlived their usefulness too.
These pics are at full flex in the front:
They also highlight another problem...with the axle bumpstop extended 6", when it flexes, your target area for the frame bumpstop to hit moves over quite a bit. So it hits off center and causes issues like seen above.
Unrelated, but equally important...my Rusty's trackbar bracket, which I've had since early 2003, has started to shit the bed.
So...step 1. Remove the stock bumpstop towers by cutting through the factory stitch welds, and breaking the few spot welds loose.
