FREE PARTS, tranny, crossmembers, shortarms, etc
bdahlg
Waltham, MA
All of these are sitting on the side of the road at my address 32 Ash Street in Waltham MA and you can grab them for FREE. I can help you load some stuff if im around just give me a call
Local pick up only. All parts below were operating fine when i took them off. My brother totaled his jeep cherokee, which was stick, so i swapped the transmission into mine
1991 AW4 Automatic Transmission - Came off a 1991 4x4 Cherokee. Has all required bolts and flywheel/dustcover, breather tubes, wiring, NSS etc. Just no cooling lines. Has 215k on it and never abused (driven for the past 100k). Shifted firm before removed.
AX15/AW4 tranny crossmembers -
Shifter lever for AW4 w/tranny hub mount - $10
Clutch and flywheel - and friction plate. I wanted to replace the clutch since i had the tranny out. This pretty much looks brand new and probably has more them 70% life left.
Rough country short arms for 4.5" lift
ECM for 1991 cherokee laredo automatic
brake pedal for automatic
tcase to shifter connector - automatic
a bunch of scrap metal
203-410-3320
Brett
