bdahlg
- Waltham, MA
All of these are sitting on the side of the road at my address 32 Ash Street in Waltham MA and you can grab them for FREE. I can help you load some stuff if im around just give me a call
Local pick up only. All parts below were operating fine when i took them off. My brother totaled his jeep cherokee, which was stick, so i swapped the transmission into mine
1991 AW4 Automatic Transmission - Came off a 1991 4x4 Cherokee. Has all required bolts and flywheel/dustcover, breather tubes, wiring, NSS etc. Just no cooling lines. Has 215k on it and never abused (driven for the past 100k). Shifted firm before removed.
AX15/AW4 tranny crossmembers -
Shifter lever for AW4 w/tranny hub mount - $10
Clutch and flywheel - and friction plate. I wanted to replace the clutch since i had the tranny out. This pretty much looks brand new and probably has more them 70% life left.
Rough country short arms for 4.5" lift
ECM for 1991 cherokee laredo automatic
brake pedal for automatic
tcase to shifter connector - automatic
a bunch of scrap metal
203-410-3320
Brett
203-410-3320
Brett
