Not happening........ when I was taking off the rear driveshaft, I discovered that the 92 XJ I picked up had a pretty serious rust problem I hadn't found. BIG honkin' hole over the cat and muffler.
So, I'm putting in new rod & main bearings, timing chain & sprockets, harmonic balancer, and so forth. And putting everything back in my 94, which is currently sitting on 4 jackstands without axles, engine, transfer case, and springs.
<grumble> Gotta learn to look MUCH harder.......
ChiXJeff
ChiXJeff
