if you are looking for an e-locker, pull an axle out of a 95 and up taco. the width will be closer to stock than a 4 runner i believe, and you'll still have to deal with the 6 lug pattern. if you pull an axle from a 95 and up 2wd non-prerunner taco, the axle width and bolt pattern will be the same. only down side is there is no e-locker for it. at least without major modification. i just put in an ARB and called good.
