jeepish
- Denver, CO
Great axles to swap into your YJ/TJ or Cherokee Jeep. Stronger than a Dana 35 and arguably stronger than even a Dana 44!
Actually have two of these, so take your pick.
#1: 98 Explorer rear 8.8 with limited slip differential and disc brakes, 3.73 gears. Should be "gone through" with any seals/etc that need addressed. Will need rotors, pads, and the "brake shoes" for the e-brake setup. Brake calipers included and lines. No cables for e-brake. $250 FIRM
#2: 2000 Explorer rear 8.8 with limited slip diff and disc brakes. Believe it is 3.73 gears as well. This is a much cleaner axle and removed from a driveable rig. Complete including rotors, pads, e-brake shoes, calipers, brake lines, e-brake cable, etc. Will need new brake pads soon though. $300 FIRM
Located in South Denver. Delivery can be negotiated if needed. Contact me at jeepcj_6 at y@hoo
