- Las Vegas, NV
For sale: 1999 Jeep Cherokee (XJ) Limited 4WD.
$5600.00 or OBO
4.0L Engine, Automatic transmission, NP242 Transfer case
110,000 miles
Dana 44 NOS rear axle with:
Alloy USA 33 spline chrome molly axle shafts
Detroit locker
Yukon 4.56:1 gears
Crane diff cover
Dana 30 front axle with:
Alloy USA 27 spline chrome molly axle shafts
Ected electric locker
Yukon 4.56:1 gears
Crane diff cover
Rubicon Express 5.5" suspension lift:
RE3715 Adjustable lower control arms
RE3780 Fixed upper control arms
RE9900 Drop brackets
RE9905 Drop bracket support braces
RE1345 Coil springs
RE1462 Leaf Springs
RE1660 Heavy Duty Trackbar
RE1665 Trackbar bracket
RE1383 3" Lower front bumpstops
RE2500 Pitman arm
RE1807 SYE Kit
Front and rear driveshafts by Dan's Driveline using greasable Spicer U-joints
Daystar 1.25" Rear Shackles
Daystar Extended rear bumpstops
DPG Adjustable Rear Bump Stop Plates
Rancho 9000 Adjustable shocks
5-Jeep TJ Rubicon 16" Wheels
4-Spidertrax 1.25" Wheel spacers
5-BFGoodrich Mudterrain T/A 285/75R16
JKS Manufacturing:
Quicker Disconnects w/ORGS disconnect storage pins
PN OGS115 Lower control arm MiniSkids
PN OGS420 HD X-Member/transfer case skid plate
SuperNerf rock rails
Custom headlight harness
IPF E-code style headlight housings with...
H4 12volt 80w low/110w high bulbs
ProComp 7" 100 watt halogen driving lights
Cobra CB radio, 75WXST
4' Fiberglass Firestik CB antenna
Solid steel tie rod from V-8 ZJ.
Custom front bumper
Custom rear bumper with 2 gallon air tank.
New exhaust system; header, downpipe, cat, Flowmaster muffler. New Bosch O2 sensors.
New starter
New alternator
New cooling system. 3 row radiator, high flow thermostat housing, temp sensor, cap, thermostat, all hoses.
5.0 Motorsports fuel injector upgrade.
M.O.R.E. Bomb proof motor mounts
Tomken gas tank skid plate
Eckhart Class 3 hitch
Both sides of front frame rails reinforced and plated
Rig Werks custom roof rack
New Battery
Spare steering components
Some rock rash.
Many more photos at: http://s1264.photobucket.com/albums/jj481/shamu613/Jeep/
The Jeep is located in Las Vegas. Always garaged.
If you have any questions or are interested, contact me via email at:
[email protected]
or call me at
(818) 584-6057
Andy
"Purple is the new chrome"
