hey Ecomike,
When you used the block tester, did you go from the radiator, or is using the coolant overflow ok?
hey Ecomike,
I was referring to the color changing tester. I have both a radiator neck and a coolant bottle.
I ran the test at the overflow bottle since there was too much coolant in the radiator neck. Fluid stayed blue and did not turn yellow.
However I'm reading that the test should have been done at the radiator neck instead.
Sent from my LGLS990 using Tapatalk
Got it. Thanks! I guess I will drain some coolant and redo the test. I figured since the overflow was attached to the neck it was ok for testing if the car was hot.Yes at the radiator neck. All gas must pass through the tester with no other gas source able to get in from outside.
You will need to drain some coolant at the radiator petcock, or a hose. Coolant needs to stay well below the radiator inner neck when hot and fully expanded!!!
Make sure you have enough room for the coolant to expand when it gets hot. All you want to sample is the vapors from the radiator. Coolant in the tester will foil the fluid, and you will have to clean the tester and try again.
I have a stroker motor 4.0 and the stock rad. It's kinda a Frankenstein motor. The 258 crank and the good head in a 98 block with descent pistons and a mild can. Built to be street able. What I did was to fight the thing going more lean. I'm using the stock 00' electronics so it's tuned really lean from the factory. When I got that with the bigger motor and stock injectors I had to swap injectors. What I gat them from was Lincoln's look a like of a crown Vic. They flow better and from what I've found the more lean it runs the hotter it runs. This was just s plug n play deal. Not mods made to fuel rail, manifold, or wiring. I only over heated once the other day when I was brush clearing with my buddy and I was driving through tall (taller than the hood) grass. It got half way to 260 then I shut it down. It boiled the gas in the fuel rail and made it hard to restart when we were done but when it was running I got out on the road and had the ac on and it ran dead on 210 all the way home. Just my experience.
Thanks. Lets hope the drain **** works on this radiator, LOL.
Thanks for the input. I have upgraded 4-hole injectors as well but I dont think it is the answer to my problems unfortunately.
