MoparManiac
- Amherst, NH
They probably converted the 350s to semi float the same time they switched the vans to the metric bolt pattern.
Run the AS numbers with the upper just underneath the floor on the passenger side.
I'd bet you'll be fine without having to cut the floor. Even then, it's not that huge of an intrusion.
Just cut the floor for a third UCA, who cares about passenger comforts?! You won't be sitting there so its not your problem![]()
