Fixing front pinion angle
I believe the ideal setting is 6 degrees less than driveshaft angle, but it looks good. Check your caster/ tire angles. If it's off you can reset that pinion to fix caster angle.
6 would be a big difference. Like ehall said, it's a compromise between caster and pinion. Unless you want to cut and turn your knuckles.
Ive tried several of the above methods. IMO, the easiest way is a floor jack under the tie rod. I can use my foot and push down on the handle while I'm looking at the bolt hole, very easy. The tie rod being farther out gives more mechanical advantage so a lot of force is not needed. That said, I have never done this method with the stock tie rod. I've done it on an zj rod and a beefier aftermarket one. It works exceptionally well.
I ran the Jeep on the interstate today for the first time with the pinion angle in exact measure with the driveshaft angle.
First time since the week I bought it that I ran 75 - 78 down the interstate with no vibrations (other than needing to replace u-joints). Smoothest ride I've had in 7 years.
I'll take that.
0-2 degree difference is ideal for a double cardan driveshaft like the front.
Use the tie rod as a jack point sounds like a terrible idea.
