HeepSpeed
- Santa Barbara, CA
also welding is required as per instructions:
"Carefully skip weld the very front and rear edges of the control arm mounts along the bottom and side of the uni-frame. CAUTION - a certified welder that can weld thick metal to thin should do this and care should be taken to protect wiring, fuel lines, brake lines, etc, and to not ignite coatings etc. on fire. Paint welded areas for protection."
