- Desert Beach So Cal
TriZZle904 said:so after i get a stroker and fix what needs to be fixed replacements etc. this is what i plan to do ... let me know whats wrong with it or what should i change or get rid of...
Cold Air Intake
Gibson Cat Back Exhaust
Gibson Shorty Headers
Helix Throttle Body Spacer
MSD Ignition
8mm Plug Wires
Bosche Platinum Series spark plugs
Upgraded Fuel Pump & Lines
Start with what will work with the stock 4.0L or the stroker:
Cold Air intake with high flow filter == OK
Gibson Cat back == OK, but find a good muffler shop and get a quote for a 2.5 pipe from the header to the Cat, a 2.5" cat-converter, a 2.5 muffler (your choice) and 2.5" or 3" pipe out to the rear bumper (there is no magic to the Gibson name or product that cannot be improved upon by a good muffler shop).
Gibson header == OK, but almost everyone trades up to a Borla or Kolak header (a header is good, just buy it only once).
TB Spacer == I believe it's snake oil (it's your money, better spent on a larger TB).
MSD Ignition == The XJ ignition is as good (save your money -- and I have MSD's on all my older cars because MSD equipment is great, but not needed on an XJ).
8mm wires == Yes, Yes, Get a quality brand (Magnacore, Sorenson, MSD, Moroso, even Splitfire).
Bosche Platinum Plugs == Yes, just not +4's, Get regular style platinum plugs (the platnium is for wear resistance, learn about plug heat ranges to select a good plug for the conditions you drive, because getting the correct plug heat range is more important than the style of plug or platnium).
Fuel Pump & Lines == save your money, because the factory pump and fuel system can easily 30#/hr injectors and it is very unlikely you will ever exceed it's capacity.
The little needs of a stroker (the process posted by Bones) is what to expect for any high performance build up. The costs exceed the budget, the little tasks & items end up costing more than the simple machine work and basic assembly (injectors, pushrods, port matching, valve springs & retainers, cam indexing, balancing the assembly, adjustable MAP & fuel pressure regulator, and custom accessories and mounts, etc.).
The needs of a mild 4.0L build up are similar to the stroker, or any engine build-up, it's just that most engine builders do not have AMC I6 performance experience and know about the little details that will end up costing you more than expected (my mildly built 4.0L in my 88 has all but a few of the mentioned modifications needed for the stroker).
I would make an effort to ask around to identify a real drag strip in the area? The BS stops when the track timers start, and there is no better way to compare not only who won, but by how much (and where on the track the winner had an advantage: start reaction, 60 foot, 1/8th mile or 1/4 mile top-end). The cost to run is cheap, and it's legal, and safe (and girls dig
