Engine swap, lifting engine?
I bought one of these at Oreillys over the weekend for $12, should be fine on that end. Was going to use the rear head bolt and AC compressor bolt.
http://www.amazon.com/Performance-Tool-W41032-Engine-Chain/dp/B000N32110
I plan to do the transmission mount while the engine is out along with the motor mounts. So I will probably drop the cross member to get to the top hex heads.
I was planning on pulling the front end off and pulling the motor by itself.
Any other suggestions or advice are much appreciated!
