Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Just dawned on me that valves can be sticky, seal one minute and leak a little or stick the next, and be slow to completely seal and close, and could pass a compression test, or presumably even a leak down test?
A Cat going bad, and increasingly blocking the exhaust would likely to make the engine tend to run rich (too little air supply) I think, and would match the low STFT numbers I was getting.
At idle the STFT was low trying to compensate for an apparent rich exhaust, while it idled smoothly, in closed loop and showed no other signs of a blocked exhaust. A low STFT in closed loop means the ECU is sending less fuel (shorter injector open time) that the data tables suggest for the other sensor data.
But an O2 sensor reporting rich exhaust (low O2 concentration) when the ECU used data tables for the fuel feed rate, and then leaned out the fuel feed to keep the O2 sensor-ECU operating in closed loop, thus the low STFT numbers, would not be from incomplete fuel burns as that would leaving excess O2, making the O2 sensor-ECU controls think it was running lean, which is not what a low STFT says?
In other words, a low STFT suggests either too little O2 (rich), or too much fuel(rich)!!!! And suggests the ECU is compensating with less fuel supply to raise the amount of unused O2 in the pre-cat exhaust???
If I am right that suggests based on all the data, that it could not be incomplete fuel burning in the engine as that would leave excess O2(lean), so it must be a blocked exhaust or intake (or valve problems), or combination.
But the original low STFT data, before the max RPM fell from 3000 rpm to 500 rpm, was when I had a suspect MAP sensor data stream (Vacuum hose leaks to the MAP sensor found and fixed just before the peak rpm and idle crapped out). And I am not sure I could see any STFT, or even closed loop operation data now, now as it barely runs at 300-500 rpm, puking all the time and trying to die.
Just thinking out loud here, trying to make sense of all the data I have.
Am I missing anything? Is this logic sound????
While this was in interesting mental exercise, I am still back to checking the Intake and exhaust for a restriction, Bad Cat? And swapping out the Cap, rotor, plug wires and CPS as the only remaining parts I have not swapped out, short of pulling the head now.
