Ecomike
NAXJA# 2091
- MilkyWay Galaxy
The base timing (timing chain and distributor are all fine, no changes made, or changes in the settings made or found in the inspection I did after the problem moved to 500 rpm. Same settings it has had for 12 years, and the same as they have been since I bought it 12 years ago). The distributor only has about 70,000 miles on it.
Tach is still normal, working fine and the Snap-On MT-2500 and my ear confirm they are all in sync on the Tach signal.
Yes, I tried clearing the Renix KAM memory once already. The STFT changed after that, but it did not fix the 2000-3000 rpm miss. I did that before it got worse, down to 500 rpm. Early on it was running rich and the STFT was compensating at idle. Now the STFT is all over the place, due to the miss fires at idle.
One thing that puzzles / concerns me is the wet oily film on the IAT sensor I cleaned yesterday when I pulled it, and the same on fouled spark plugs.
I wonder if the valve seals are shot after using Pen lube on them???? Oil fouling from shot valve seals???
But how did I oil get all over the IAT sensor. The EGR is working properly. Maybe backfires on decel???
hows the timing on it? have you ever changed the chain or removed the distributor? the only thing i can think of is its losing its crank signal. is the tach jumpy when its hesitating?
also STFT should be jumping quite a bit. LTFT wont really change until you drive it.
have you disconnected the battery during any of the diagnostics?
