Green XJ Jeep
- Spanaway Wa
It would be kind of a pain but how about unplugging the pump itself. Then it wouldnt matter what voltage is getting sent to it.
I am afraid that would lead to replacing both connectors at the fuel pump. If it ain't broke don't fix it or even touch itLOL.
Forgive me if it's already been mentioned, but what about
the TPS/Throttle Position Sensor?
The exhaust popping could indicate a broken or very weak exhaust
valve spring, but wouldn't explain the rich mixture...?
MT2500 knows nothing of the vehicle sensor's grounding. Only what it's output is.
Test the ground between the MAP terminal and the battery neg terminal.
What does a visual on the spark tell you. Pretty easy to pull number two plug, open up an old plug to 0.060, ground the plug and look at the spark.
When my idle messes up this is usually my first check. I use my Renix on my hunting lease, mud puddles splash all over the engine compartment. I've had numerous low voltage to the ignition module episodes cause weak spark, line lose through water in the connectors or where ever. If you find you have weak spark you can start back tracking and find the cause.
I don't really know what your issue is, to much fuel (MAP?), CPS missing/skipping pulses causing poor ignition and excess fuel or an ignition issue?
.......Still will run, but only runs, stumbling badly at 500 rpm and does not care if the throttle is at idle (actually need to open the throttle just a little bit or she dies after 10 seconds) or at WOT, which puzzles the hell out me. Its like its getting the same amount of fuel and air at idle as it does at WOT. It runs the same, same stumble at WOT as it does at idle.
Could the throttle body throttle plate be not opening and just the shaft is moving? It feels normal when I rotate it by hand. I will need to pull the intake hose again to check that.........
Can you do a leak down test ? Seems about the only thing left.
This sounds like a carburetor with the choke stuck closed.
I assume you did check to see that the throttle plate was
indeed opening up with the throttle linkage?
A clogged cat can cause these symptoms, but I know you've already checked that.
Maybe rig up an intake manifold gauge and see what the
actual intake vacuum is. That should give more info on
the problem...
This is a real mystery.
I would try another CPS. I don't care how new the old one is.
