ddeadserious
- Detroit
My (aux.)electric fan used to work.
Now it doesn't most of the time.
Sometimes it does, but more often than not, it doesn't.
It's supposed to turn on when the temp. gets to 210, but it doesn't except for some times, randomly.
The plug for it is tight and clean.
The fuse is fine, and I switched the relay with a known good one to no avail.
The plug is just a 2 connector plug, would that be one for power, one for ground?
Other than "jumping it" with aux power to see if it's a fan or electric issue, what else could I do to check?
Is there any reason I couldn't tap into the wires to send power to and jump the fan?
Thanks, this is a 92 XJ.
