themangeraaad
- Halifax, MA
So I am in the middle of rebuilding/installing a durango steering box and decided that while I had it apart I might as well drill/tap the box for hydro assist in case I want to add hydro assist later on down the road.
So lets just say it didn't quite work out as planned. I drilled and tapped the hose and to be honest I'm really not sure what happened. All I know is that in the end the threads on one of the holes got mangled somehow and I've decided to just give up on the hydro assist idea for the time being; the durango box with WJ pump should be enough for the driving/wheeling that I will be doing for now.
My question: Will patching the hole by welding a piece of scrap steel on the outside of the box cause any adverse fluid/flow issues for me? I realize that instead of having smooth channels for the fluid to flow there will be a hole/patch in one area which might cause some turbulence and not-so-ideal fluid flow, though I'm guessing if it's not moving TOO much fluid too fast that might that might not be an issue... but I figured I'd check with you guys first to be safe.
