driveshaft length
DurbElites
Simi Valley
I have a chry 8.25 with a driveshaft made for that axle (length wise) and I just got a Dana 44 and I know they are longer in the pinion area so should I invest in a new driveshaft considering that I have only about two inches of spline travel before it bottoms out at ride height. o ya I have 4.5 leafs and 1.25 RE shackels
I would think with that much lift you should be fine. Throw in a few extra inches of rear bump stop. I think the 8.25 and 44 are pretty close in pinion length. The D35s are shorter.
X2, I just bought an XJ D44 and after some initial measurements they come out pretty close. Although I'm running more lift than you (6") I think you'll be okay.
OK, so I'll dredge up an old thread.
ALL OTHER THINGS BEING THE SAME, what is the difference in driveshaft length between a D-35 and a D-44???
thx
thx
Also could you use a DS from a 87 Cherokee w a D44 on a 242 TC Hack-n-tap using said d44 W/ 6" lift.
I figure you should be ok. I just replaced my D35 for a D44 scout and my DS was already custom made. I only had to shorten in about 2 3/4" could've possibly gotten by with 2 1/2". The 8.25 and D44 aren't that much different from each other.
