So I just decided to update this thread, even though its quite old, as I finally got around to puling the case out earlier this year, and I finally got around to opening it up this past weekend.
I will say that I continued to use the transfercase for a while, it was quite angry when I was driving around in 4wd full time last December, it was HOWLING horribly.
First:
I do have AAA. Out of the 2 times I've called them, I've ended up having to cancel the tow both times. Who knows, 3rd times a charm.
Oh man, I wish I could return to those days. I've used AAA so much in the past year and a half, I almost maxed out my tows last year. AAA gold is one of the best things you can get.
As far as the case goes, those pieces were
NOT the shift pads, as previously suggested in this thread, and the case was not cooked.
When I opened it up, these 3 pieces also fell out:
I found the magnet to look like this:
I noticed this crack. Originally I was thinking it might have been from when I was opening the case, but judging from the second picture, you can see the fluid stain that has dried right below the area of the crack.
Not sure how that crack got there.
The stain below the cracked area, crack, which goes through the bolt hole, visible at top of picture:
Found this:
And the shift forks. The center one is crooked because I took it off, and just through it back on there for the picture.
So that is as far as I got with the case. I have a feeling it is from inside the differential for the full time. It seemed to have quite a bit of backlash before the visible gears would start spinning, and it was howling before I took it out. I'll take that apart whenever I get a chance, which won't be soon.
