BrokenSockets
- Ayr, Ontario
96 country AW4 242
Am I right that I should be able to pop the front axle/unit bearing/rotor out all in one piece to change the u-joints? My crappy repair manual says I need to open the diff cover and remove a c-clip, and remove the hub nut. I read posts here saying that's not so.
Should I be able to remove the caliper, 3 13mm bolts, and use the short extension between the axle housing and yoke trick to just pop them out?
Don't want to take apart anything I don't need to.
