Builderxyz
- The Desert
looking for a place in so cal with the most reasonable prices on DOM tubing.. 1.75 x .250 wall
Thank you i will call them in morning!Yep, and Ballistic wants $14/foot. OUCH!!!
Luckily you aren't building a cage here![]()
If you're building a 3 link, you're going to need around 12-13 feet, so you can see how much this will cost you online.
I get all my steel from Palomo's Steel in Long Beach. They have the best prices I have seen and I've been going to them for years. Give them a call tomorrow to get a quote for what you need as a comparison.
JJS Palomo's Steel Inc
maps.google.com
2102 E Curry St
Long Beach, CA 90805-3208
(562) 984-7505
I wouldn't use 1.75" OD 0.250" wall DOM for the lowers if that what your plan is.To be used for control arms on 3 link suspension..
The 3 link will be a mid arm, in the 20" range.1.75 x.250 will be plenty strong.thanks again everyone.I wouldn't use 1.75" OD 0.250" wall DOM for the lowers if that what your plan is.
I only have a few runs on my front and they have a slight curve in them (nothing worth replacing, just worth noting, about 1/8" over ~36") they are 1.75" OD 0.375" wall DOM.
My rear 2" OD 0.375" wall DOM lowers are holding up much better. When I redo the front ones, they'll be made from the same as the rear.
