Disco D30 to one piece shafts, Warn axle seal part #?
zeejay
Shoreline, Wa
Swapped in a hp 30 out of an XJ, and it's leaking like crazy out of the long side tube. Everyone said I need the Warn axle seal, any one know the part number?
I have the little kit that comes with their axles - (blockoff plate, and two seals) Its yours for 20$ if you like...
Is the housing you got have the vacuum disconnect or is it a long single shalf housing... If there is no disconnect housing you probably just shredded the seal at the diff (go to the dealer)...
HTH
Matt
HTH
Matt
Right on, is there a part number on the seals? Are you ever closer to Seattle someplace i could meet you? Since the Jeep is pissing fluid super fast, I don't like to drive too far.
I know 2 part #s for inner seals from National
NS 471354 with an OD of 2.062"
NS 471763 with an OD of 2.000"
or get a complete block-off kit with plate and seals for about 30 USD at Randy's Ring & Pinion.
