- MilkyWay Galaxy
I would not trust a helicoil on a head bolt for 110 lbs of torque, I would scrap the block, or ask a local engine machine shop if an over sized bolt can be used, but even then I suspect it asking for trouble!!!
5-90 taught me a trick, you take 2-3 old head bolts, cut off the head, and then cut a slot in what was the head end of the bolt. Thread them in the block and then use them for guides for getting the head lined up properly. Then use a long blade screw driver to remove them. Works great!
Also it is easy to damage the head gasket, so you want to get the head on there once, and get it on right!!! So make sure you have enough strong armed people, or equipment to lower it slowly. The hardest part is getting the rear bolt in. You either need to drop the engine/trans some, or install the bolt in the head first!!!! I installed the bolt first and used duct tape on the top side to hold the bolt up enough to keep the threads from being exposed on the bottom side until the head was in place. Then just remove the duct tape once the head is on the block!
Also you want to either paint the head gasket with aluminum paint or use Indian head gasket shellack
on the gasket.
The copper RTV works the best!!!! We installed the manifolds before we put the head on, so it was heavier and bulkier, took 3 of us. But it made torquing the manifold bolts a lot easier.
on the gasket.
