- MilkyWay Galaxy
To non-OP poster, ihscoutlover:
Anything under 120-125 PSI is too low and needs repairs. The MAX allowed delta P, between two adjacent cylinders is 20 PSI!!!
VERY, very hard to believe a jeep can get 18 MPG with those super low compression numbers, 90-115, WOW!!! New 4.0 is about 170 PSI, IIRC, 160-170 is normal on a new engine!!!
You might retest with the wet method, add a teaspoon of oil into the spark plug hole first, then retest. If they are still that low, you have serious engine problems, and it is hard to enough get combustion that low, with out frequent missfires.
Sounds like some serious coolant leaks (head cracks) into the combustion chambers.
