Dirt Bound Offroad Trailer - Build Log
Yup, that's the XJ.
I did retain some wood on this project, just got some 3/4" exterior grade plywood for the floor. it will be sealed and painted then bolted in.
I got some new foam for a new mattress and made a new cover for it. I mounted it to the jeep and tested it out and I slept so well... Ill never use a ground tent again haha.
This morning I headed to the steel yard with a bunch of sizes and had them cut up 2 4x10ft 16g steel sheets, $160 later I had my steel for the sides.
The front box I folded the top lip. (It helps I have a shop full of metal working tools.)
The sides I welded on the inside so once it is done you will see the frame work.
The trailer looks sweet! Where was this picture taken though?
