If yours is not easily legible, it is not LED. Jeep used two kinds of clocks. One is an LED, and that works very well. The other is an LCD, which uses a #74 bulb as backlight. If you can't see yours, you probably need to pop the dash bezel, pull out the clock and replace the bulb.
