It is a complete LS1 and 4L65E with computer, engine harness, torque converter and drive shaft. The engine was assembled ran a few times and then taken down to short block to remove it from the car. It has sat for a couple years and there for will need to be opened up, cleaned and reassembled. It will need a re-hone. The tranny has less than 10k miles on a rebuild and a transgo stage 3 shift kit.
Parts:
Diamond forged 11:1 Pistons
Diamond Pro Select Rings
Diamond Tool Steel Wrist Pins
Eagle H-Beam Forged rods
Thunder Racing Chromoly Push Rods
Coyles Double Adjustable roller timing chain set
Ferra gold Dual Springs
Ferra Titanium Retainers
Ferra spring locator set
ARP Head and Main Studs
Heads Ported
LS6 Intake
G5X2 Cam
Comp Lifters
APE Ported LS6 Oil Pump
ASP Under drive balancer
Hypertech 160 Thermo
http://i163.photobucket.com/albums/t282/obsolete346/Tranny.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Piston.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Head3.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Head2.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Head1.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Engine1.jpg
http://i163.photobucket.com/albums/t282/obsolete346/ASPPulley.jpg
Chassis
The car was being built to be a race car/street car so there has been a bunch of lightening, rad support, inner fenders, foam and bumper mounts are gone. Also the HVAC, carpet and seats are gone. Most everything else is there. It has BMR k member and will have the stock 5 spoke rims and 10 bolt with 3:32 gears and a stud girdle cover. This is a tan top convertible with a clean title. Flip up headlights work fine.
http://i163.photobucket.com/albums/t282/obsolete346/Chasis12.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis11.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis10.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis9.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis8.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis7.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis6.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis5.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis4.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis3.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis2.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Chasis1.jpg
Moser 12 Bolt 33 spline / spool / girdle cover
The housing and axle have some surface rust and will need to be cleaned up a bit.
http://i163.photobucket.com/albums/t282/obsolete346/RearEnd.jpg
http://i163.photobucket.com/albums/t282/obsolete346/Axles.jpg
Take the every thing (Motor, tranny, car, rear end) for 4,500 obo. I will not ship this. This is not a part out. Take it all.
Parts:
Heads Ported
LS6 Intake
G5X2 Cam
Comp Lifters
Chassis
