YELLAHEEP
- Littleton, Colorado
I'll give this another try before it gets sent off to languish in storage. Feel free to cross post, put it on Facebook, whatever.... I'd appreciate any help to get it sold.
Still have this truck that was gonna be my Dually project but I just need to move on. Truck has not been modified for the dually project so it'll be a super nice clean truck for someone. I'm keeping the dually parts - maybe I'll find a solid running Metric Ton in the future and build it then.
'88 long bed 4.0, 4x4 5 speed non-A/C truck from New Mexico........ yep...... ZERO rust. And a stupid-straight body. This is a factory gas and t-case skid equipped truck with tow hooks.
The guy got a notice from the city to get rid of it and since he'd removed the engine/trans/t-case and axles from it..... he decided he couldn't get it together in time and decided to sell. He had bought a bunch of brand new lift parts, 31's and whatnot, and the engine was blown so we struck up a deal where he kept the new parts, builder engine, trans and t-case to sell off and I bought the roller body.
It was his father's truck since new. He wanted to do a resto-mod. Helluva nice base-truck for my project. The bed had a topper on it all it's life so the bed rails are perfect except for 6 bolt holes from the topper. Perfect bed all around. Perfect tail gate too. Never been in an accident, the only body filler is on the right rear and that's very minor.
The odometer says 30K miles....... unfortunately, it quit working years ago. His father kept oil change records and the last oil change was at 145K before it spun a bearing. Being that I wasn't interested in the drivetrain, mileage really wasn't a factor.
The maroon interior is damn near like new. The bench has had that seat cover on it since new - so he says.
It has rebuilt rear leaf packs with new leaf insulators and bushings, and a 3" AAL. The front has a new poly bushings, Black Diamond 3" lift arms upper and lower. The coils were shot and he cut those out with a torch, so I popped in a pair of Metric Ton front coils to get it home.
He also installed clear corners and signals with new halogen head lights, then painted the grill/trim.
Has a plastic bed liner, over the rail style.
I bought Kaczman's buggy - what was left of it anyway with the stroker he built. That stroker is now in the engine bay of this truck with an auto trans bolted to it. The trans is a 23 spline output. Do the mods to swap to auto or put a 5 speed back in it. Again, nothing has been modified yet. If you want a column shift auto set up, I have those parts available - at additional cost. Realistically....... going back to a 5 speed makes this truck very quick and easy to get back to running status....
Stroker build info:
-OEM Renix block, Head was ported and polished.
-12 counterweight crank (I believe he said it was new, aftermarket)
-Comp Cam (part number was either 68-231-4 or 68-232-4)
-Custom dished pistons for 9.4:1 Compression Rating
-Mopar Performance Valve Springs, Retainers and locks
-24lb injectors
-Mopar performance plug wires
-Balanced and blueprinted
-235 HP and 250 ft/lbs torque
Also have a nice pair of maroon big-bolster bucket seats with MJ bases available if you don't like the bench - at additional cost.
Comes with a tube rear bumper but have a perfect OEM rear bumper available - at additional cost.
It will need a windshield, a radiator and an aftermarket track bar and drop bracket for 3" lift.
Anyway, this is likely one of the cleanest rust free trucks you're gonna find and it's got a stroker.
$2,500. Screaming deal....... If I can't get that for it, I'll continue to sit on it.
Stroker build info:
-24lb injectors
