rockcrusher
- georgia
Before I installed my lift (4.5 RC AAL) the front tires would shake at about 40mph. After I installed the lift same thing. I changed the wheels and tires still the same thing. I sort of fixed the problem I moved the wheels out so they werent straight and it drove ok. I took it to the shop and they did a alinement on it they said it was out by 3 inches. After that it drove fine up to 40 mph againg so when i got home i backed them off again drives ok. when i hit a bump the whole front end starts to violently shake again and then stops. Im thinking that im going to replace all tie rod ends ,drop pitman arm, and ball joints. Dose that sound right? Its a 89 aw4 4.0 242. I"d like to upgrade is there is a direct replacement. As everybody money is tight. maybe pap?
Thanks
Thanks
