dana 60s front nad rear question
blondejoncherokee
sacramento
anyone know what a closed knuckle front dana 60 with drums goes for that needs spiders ?
i know a good front 60 can go for 1000$, but im not familiar enough.
good to know.
would it be worth even 300$ even with the messed up spiders?
or is it a overpirced paper weight like any dana 35 for over 20$?????
plus itll need a front disc conversion..
damn
im gonna see what i can come up with for an offer.
it has an atlas
so would these axles be worth (60 rear too with good spiders) say 400$ for the pair on cl or pirate?
or more like 200$
I wouldn't run a closed knuckle 60. By the time you swap to disk and realize you have funky tracta' joints in the knuckles you will cry. Save up for a real 60 if you want one. I believe they are 30 spline inners anyways.
atlas sold so im not even interested in the jeep anymore . sold atlas an hr after i called!
anyway he has a 96 dodge ram supposedly with 60's front and rear with factory posi 's too.
i only know xjs and scouts, but are these axles worth it?
i can get it pretty damn cheap since the tranny is shot
96 Ram front 60 is a CAD axle with 30 spline inners and no way to do high steer. It can be used but again, its a weird axle. Front unit bearings are usually junk too.
Stick to Jeeps Jon some of the Dodge stuff is funky. Like rockslut said unless you want to fix it and resell the rig or make it a tow rig. Otherwise say goodbye. If you find a 1975 to 1979 Ford F-350 then make sure I am your first call buddy. I would buy a high pinion dana 60 in a minute should have never sold mine.
Wow that makes me feel even worse mine was a 79 high pinion 60 why did I ever sell that truck. ???????????????????????
The only 94+ Ram front 60 I would consider running would be an 02. Non disconnect and 32 spline outers. 03+ are the 9.5" AAM axle and are good too. Still no high steer options and no locking hubs.
good to know. im passing for sure.
he basically would have sold me the ram for cheap with brand new 31s, hd231, rest of vehicle etc
