Chief93XJ
- Southcentral PA
I have for sale a set of used gears and open carrier from a mid 70's Dana 44 Heavy Duty High Pinion axle. the gears are in great shape and still show machine marks from the factory on the teeth. the bearings and races are included as are the original shims. they are mounted on an open carrier. the bearings are in good shape also and can be reused. One of the side gears has some gunky crap built up on it, it only needs to be taken apart and cleaned up good. If you are not happy with condition of the gears when they arrive i will refund your money, less shipping . remember that these gears were mounted ina high pinion reverse rotation front axle i that makes any difference. $75 obo located in Blairsville PA 15717
