dana 30 driver side knuckle
I have one only thing it has been drilled to 5/8s I believe.... for a heim joint
let me know if you can make it work
unless it's like 90 or older, the caliper brackets are part of the outer knuckle. often times the pad will wear into the slider parts of the caliper brackets, warranting replacement of the whole freakin outer knuckle. that may be his issue.
I have one from a 91 xj. It's in good shape, and I'll sell it to you for $40 shipped.
Jake
