Hillbillymark
Hello everyone, I have a 96 cherokee country
with an automatic tranny a NP242. I have an ABS light on the dash. I replaced the tone ring and abs sensor on the driver front and cleaned the other sensors and tone rings. I am getting a signal from the sensors with the multimeter.
I tried using 2 different scan tools to read codes and both of them will not make a connection with the ABS system. I have power all the way to the module, so I assume the module is bad. Are these modules year spacific or will any module work.
Thank you
Thank you
